remote programming
Old Apr 25, 2008 | 08:09 AM
cameron's Avatar
Default remote programming
i have a 1999 XJR. I have the instructions on how to program it. I opened the drivers door, I opened the boot, I put the key in the ignition and turned it to position 2(accessories on, engine off)(dashboard message panel is flashing door open, boot open), I hit the Valet switch 5 times....nothing. No chirping, no flasjing lights, nada. The troubleshooting guide says to 'check' the valet switch. Well, it works fine to lock the boot and goes into Valet mode, so I am assuming the valet switch is working just fine since it is doing what it it supposed to. How in the heck do I get it passed this point and into the 'programming mode'? Will the dashboard message center state 'in programming mode'?
I even tried the instructions for XJR's with no Valet switch (the flashing of the lights 4 times, etc) Nada.
Any other suggestions would be welcome!!!!
Old Apr 25, 2008 | 07:26 PM
jag_genius's Avatar
Default RE: remote programming
that for a xj6 1995-1997
Old Apr 25, 2008 | 07:29 PM
jag_genius's Avatar
for xjr open door pull hi beam towards you then turn key to position 1 then let go of hibeam then pull it back 4 times then you will hear a chime.. then take key out and press unlock on every remote you wanna program .. you will hear chirps when unlock button is pressed then insert key and turn on.. then you will hear a confirmation chime.. then your done
Swagguar
Sep 30, 2015 01:34 PM
redxk8
Sep 30, 2015 08:18 AM
zdrapec
Sep 25, 2015 05:49 AM
kevinl
Sep 24, 2015 08:25 PM
