Replacement for LNA4145CA - Daimler Super V8 A-post loudspeaker
Hi all,
I'm looking for a replacement for LNA4145CA, the A-post loudspeaker (tweeter), which was used in the 1998 Daimler Super V8 (VdP overseas) Harman/Kardon premium sound system. When looking for the original part I found out it is not manufactured/sold anymore.
So, anything that will fit nicely and will be compatible with the system?
many thanks.
many thanks.
I have a 1999 Super V8 and did the tweeter replacement. I found out that the small tweeters are Audax TM010A1. You can buy them here: https://www.madisoundspeakerstore.co...=Audax+TM010A1. Remove the bad tweeter from the Jaguar plastic bracket and insert the new one.
If you can get ones from the 00-03 XJ Alpine premium sound systems they're a drop in fit, and a big upgrade with soft dome tweeters in place of the plastic ones used on the HK systems. Not sure about the part number though
