Rochester pressure valve x308 Cheers, Tony
Did anyone ever find a way to replace the pressure valve with an alternative now the Jaguar and the GM ones are no longer available? H have high pressure when opening the fuel/gas cap? I have searched the forum to my new member abilities and cannot find an answer. Sorry if it has been covered already.
GM 17089068 is AC Delco 214-552 - Vapor Canister Valve ACDelco GM Original Equipment 214-552 | eBay. It seems that the "CAN' and "TANK" ports on the GM/Delco part are swapped 180 deg. compared to the original Jag valve so one should follow the port markings when connecting the GM valve, not its shape.
jadedragon1800
Jun 7, 2011 10:30 AM
