Should I be concered about this gearbox?
Old May 14, 2022 | 06:08 PM
asjdhsajhdfj's Avatar
Default Should I be concered about this gearbox?
Hi,
I have seen a 2000 XJ8. Gorgeous, most dealer stamps. All rust work done, however, the gearbox is confusing.
It is aggressive on the downshifts, according to the seller.
If it was supposedly serviced regularly, it makes me believe the transmission fluid isn't the issue. It is concerning as the car is sitting on 78k.
My XJ8 would do this but it needed a transmission fluid top up..this was at 178k.
What do you think?
Old May 14, 2022 | 08:09 PM
Highhorse's Avatar
You could need a new valve body as described by Gary here....
He describes the main issues with this trans, the final one sounds like what you describe.
But, you may be able to get ahead of it before it breaks and replace the pressure regulator valve with this kit...ZF5HP24 Valve Body Pressure Regulator Valve Repair Kit.
https://www.ebay.com/itm/12199764772...sAAOSwjDZYkig~ ...thing is I'm not sure how available this is in Europe?
Old May 15, 2022 | 03:05 PM
Mike K's Avatar
https://youtu.be/DsQqpkC8Xs4
This is very important to do on any XJ or XK that hasn’t had it already… on mine, when the pressure valve went, it blew out both the a drum and the valve body. It ended up needing a full transmission rebuild, around $4,000.
I remember that it went out while downshifting as well.
HermesGovantes
Mark V - X 420G
Jun 15, 2021 10:53 AM
Yoosey
Dec 23, 2018 10:28 AM
matt0091
General Tech Help
Jan 20, 2017 12:14 PM
Mr. Barry
E type ( XK-E )
Nov 18, 2014 07:45 AM
