Smell of antifreeze
I have a 1999 XJ 8L and I can smell antifreeze/steam after driving the car and shutting it down. Also have to put about 20 oz of antifreeze every 3-4weeks.Any suggestions/Help?
I had a leak @ the plastic t-stat tower/housing seam, it wasn't visible until I had to dig in there to replace a knock sensor. I was adding coolant about every 600 miles or so. Replaced the housing & no more issues.
There are a lot of places that can leak without being obvious. If you can locate a shop that can perform a pressure test that is usually the quickest way to fix a leak without throwing parts at the car.
The tstat tower is certainly a common source of trouble, and replacing it with an aluminum one with new tstat is always a good idea.
That low coolant light was a thorn in my side for monthes prior to the knock sensor reveal lol.
