Taillight & Blinker issues
Old Jan 29, 2015 | 08:39 AM
Gezongaz's Avatar
Default Taillight & Blinker issues
Morning Everyone -
New to the forum - first post. I recently bought a 2001 XJR with 145k. The car is having issues with tail lights and blinkers; I'm hoping to learn from all of your knowledge and experience.
Here's the story....
When i bought the car I was told that the front right blinker had failed just a few days ago. The car is sending 'check rear lights' warning at the dash and the right front blinker is only drawing approx. .5 - .8 volts while 'flashing' while the left front works and is pulling 3.5 - 7.5 while flashing. I've check for obvious fuses and broken wires nothing.
Also - I noticed something fish. Someone had installed a 'after market' ground wire from the rear marker lights 'through' the left taillight connections' ground to the right tail lights connections' ground and ending at the negative post on the batter. I disconnected that mess yesterday - no change to the existing problem.
What works
  • headlights (when turned on at the column only)
  • break lights (when pedal actuated)
  • left blinker (front & back)
  • right blinker (rear only)
  • fogs
  • rear fogs
  • brights
What doesn't work
  • Auto headlights
  • any running lights (front or back)
  • right front blinker
I spent last night checking each fuse & relay box (2 @ engine, 2 under rear seats, 1 in trunk) and all fuses are O.K.. The front blinker bulb is brand new, connections cleaned, dielectric grease.
Anyone have any thoughts? trouble shooting test? something I'm not aware of? Relay to test?
thanks in advance
Old Jan 29, 2015 | 01:56 PM
Gezongaz's Avatar
Bump to top
99xk8guy
Sep 29, 2025 10:51 PM
99xk8guy
May 28, 2024 09:36 PM
JarodL
Mar 7, 2024 01:39 AM
joey g
US Northeast
Sep 7, 2015 06:28 PM
carelm
Sep 5, 2015 01:13 AM
