Torque converter Bolt Size? XJR '99
Old May 15, 2017 | 10:01 PM
vsol's Avatar
Default Torque converter Bolt Size? XJR '99
Slightly stripped one of the torque converter bolts and I would like to replace. These are the set of 3 bolts that you see by removing the rubber access panel right by the torque converter.
I believe they are m10x1.5 ? can anyone confirm this and the length?
Old May 16, 2017 | 07:59 AM
Highhorse's Avatar
One of 2 suggestions I would have, not knowing the size, is to take either the good nut and/or bolt to a local hardware store (usually an ACE for me) and find the size that way (and usually the replacement in grade 8)...making sure the heads and/or seats are identical. Or, take it down to the local indy or Jag parts dept and see if they have one or can get you that.
I know member Daim has recently done some transmission work, but I am unaware if he knows the size you ask?
Old May 16, 2017 | 10:16 AM
vsol's Avatar
I got this search result from autozone when putting in XJR for vehicle.
Help Torque converter bolts 14040 - Read Reviews on Help #14040
i will try these and report back
