tow ball weight
If you're referring to the weight on the ball itself, and not the actual towing weight, the manual stated the following:
Trailer (w/brakes) - Recommend 3307 lbs / 1500 kg
Trailer (w/brakes) - Maximum 4188 lbs / 1900 kg
Trailer (unbraked) - 1653 lbs / 750 kg
Trailer nose load - 167 lbs / 76 kg
Taken from the following thread, and there are photos from the manual pages with much more info:
https://www.jaguarforums.com/forum/x...ow-bar-187042/
It is actually quite high. Consider, it is only a saloon/sedan. Even the most rigid and stiff cars from Volvo (200/700/900) have a 75 kg load. So it is actually quite sturdy. My Pa's Fiat Ducato van (Dodge ProRam) has about 80 kg...
Teck4Jag
Mar 15, 2017 01:46 PM
FS[NorthEast]: 2004 VDP Fix or Parts $1500
rudelover2
Nov 29, 2016 07:41 AM
