Transmission Fill
Old Aug 30, 2014 | 11:47 AM
larney's Avatar
Default Transmission Fill
Wanting to drive to the beach today. Checking all fluids and want to make sure the trans is topped off. Which one of these plugs is the fill/check plug? Any help would be greatly appreciated...
Old Aug 30, 2014 | 12:28 PM
RJ237's Avatar
The answer is C. Just to be sure you know: Do not remove the plug unless the engine is running. The fluid temp. should be 30-50 deg. C. I measure it by sticking a indoor/outdoor thermometer sensor in the fill hole, and close it up if fluid dribbles out at 30- 35 deg.
bamforp
Aug 14, 2024 05:36 PM
tomsjag
Jun 10, 2023 10:02 AM
Jandreu
Jun 30, 2022 03:10 PM
mrplow58
Sep 15, 2015 09:58 PM
chatmanx
Sep 11, 2015 07:17 PM
