Transmission fill level by tilt?
Old May 14, 2017 | 09:31 AM
Ophitoxaemia's Avatar
Default Transmission fill level by tilt?
Wondering if the extra amount of fluid needed between hot and cold could be simulated by tilting the car when filling cold?
Perhaps the difference is too great, but don't like the idea of being under the car when running. I don't have the most secure footing for jack stands.
Does someone know the amount extra?
2000 XK8 Coupe
Old May 14, 2017 | 03:29 PM
Stu 1986's Avatar
Ideally you should try and get access to a ramp or better hard standing. When I filled mine, I deliberately overfilled it because I knew a bit would flow back out whilst I was refitting the fill plug.
