Transmission PRV Replacement
Old Mar 28, 2016 | 01:39 PM
Bcrary3's Avatar
Default Transmission PRV Replacement
In the next week or two I am planning to replace the PRV in the valvebody to prevent A clutch drum failure.
I am about to order the filter and the valve this week and the ATF (
Amazon.com: Castrol 03520-3PK Transmax Domestic Multi-Vehicle Automatic Transmission Fluid - 1 Gallon, (Pack of 3): Automotive Amazon.com: Castrol 03520-3PK Transmax Domestic Multi-Vehicle Automatic Transmission Fluid - 1 Gallon, (Pack of 3): Automotive
) next week, the question is, when I do this job, how much ATF is typically required? Will 3 gallons be enough or should I get 4 to be safe? I am not flushing the trans, simply dropping the pan, taking out the valve body, replacing the PRV, and putting a new filter & gasket on.
I am mostly curious if I will need more than 3 gallons of ATF and if so, how much more? Also, will the ATF in the link work? I though someone on here said they have been running it for a few years without any issue. The car has just over 118k on her.
Old Mar 28, 2016 | 02:26 PM
harvest14's Avatar
Maybe it's my imagination, but when I did that job it seemed a lot more fluid came out when I removed the valve body. It took almost 7 full liters for me to get the transmission full again.
Old Mar 28, 2016 | 02:41 PM
Bcrary3's Avatar
Wikipedia says this trans only holds 2.9 gallons of oil, but from what I have read it seems like more?
I'd imagine a lot of it would still be in the torque converter?
That's only 1.8 gallons.
Old Mar 28, 2016 | 02:54 PM
RJ237's Avatar
Harvest is right. You will probably need about 7-8 qts. with the valve body out. The Castrol is what I and several others are using.
You can also use it to flush your power steering reservoir. Just use a baster to remove the fluid in the reservoir and replace with fresh. Do it every few days until it comes out clean.
Old Mar 28, 2016 | 02:56 PM
Bcrary3's Avatar
So I should be alright if I just get two gallons? Not 3?
I replaced the power steering fluid a few months back and had my shop do it using a special vacuum (replaced using Dexrox VI)
Old Mar 28, 2016 | 06:49 PM
RJ237's Avatar
I think so. But it's a good idea to do a simple drain and replace a couple more times, since there is still old fluid in the TC. I would go for the 3 gal. for that reason.
Unhingd
Nov 5, 2025 08:45 AM
XJ6Paul
Jun 4, 2019 01:23 PM
Britrover
Mar 10, 2016 10:49 PM
klfong
Mar 6, 2016 12:08 AM
dogsoup
Mar 4, 2016 07:33 AM
