Trunk lights
Old Feb 22, 2014 | 02:55 PM
firenfix's Avatar
Default Trunk lights
I have 13+ volts to my trunk lights, but they won't light up? Take the bulbs to a remote 12 volt battery and they light right up.
Thoughts?
Old Feb 23, 2014 | 10:38 AM
mikebaker3's Avatar
I am having a similar problem, but mine also involves the trunk latch and license plate lamps.
A comment to my post suggested that the trunk(boot) lid wiring harness may have broken wires because it is flexed over and over every time the trunk is opened and closed. You have a separate ground ire for each circuit, so run a temporary ground to see if you might have a broken ground wire.
Old Feb 23, 2014 | 04:32 PM
firenfix's Avatar
Thanks Mike. I was able to open the trunk latch micro-switch just enough (without removing) to clean out with some spray and compressed air. Worked it a few times and the lights started working. I still don't know why 13 plus volts at the socket wouldn't light the lamp prior to cleaning switch, maybe a ground issue? Anyway, you may want to try that. I checked all the wires at the right trunk hinge first, all seemed to be fine.
mbergen
Oct 23, 2019 10:26 PM
martybmw
Apr 2, 2016 04:55 AM
XJsc-guy
Nov 23, 2015 01:56 PM
prettydaim
Sep 7, 2015 05:16 PM
02jagstype
Sep 4, 2015 08:20 PM
