Unable to reset keyfob remotes
Old Apr 1, 2010 | 10:49 PM
perezal's Avatar
Unhappy Unable to reset keyfob remotes
Replaced my SCLM in my 2001 VDP SC with the correct module and 3 diget programming security code. The unit installed fine "plug-n-play" however I am unable to reset my remote keyfobs. I have followed the instructions from other posts and the set-up appears to work however when I press the remote buttons I do not receive a confirmation chirp. The unit is a used on and I am wondering is these SCLM may need to be reprogrammed?
Al Perez
Irvine, Calif
Old Apr 2, 2010 | 04:01 AM
Sean B's Avatar
have you replaced the batteries on the fob?
Old Apr 2, 2010 | 08:50 AM
perezal's Avatar
Yes I have replaced with new batteries in the correct alignment.
Old Sep 13, 2010 | 04:23 AM
bzguy's Avatar
are you sure about the fob frequency model ? Read that they used several frequencies over time
Old Oct 13, 2010 | 05:05 AM
garethww's Avatar
Hi Al
Please let us know if this has been resolved. I have the same symptoms on my car. All the doors lock with the car ect and the alarm beeps but I just cant get the key fob to work. Its the second unit supplied with the car so is definitely the correct frequency and it has new batteries fitted correctly.
Msteiner
May 16, 2016 12:19 AM
hoodun
Oct 6, 2015 08:34 PM
millertic
Sep 30, 2015 08:11 PM
zdrapec
Sep 25, 2015 05:49 AM
