Upper control arms
Old Oct 24, 2025 | 11:19 AM
jrb53's Avatar
Default Upper control arms
2000 xj8 I need to change upper control arms but having trouble getting them will a Lincon lS fit as they are readily available if where ca I get jaguar ones without spending a fortune. Thanks jrb53
Old Oct 24, 2025 | 11:44 AM
pcolapacker's Avatar
Just replace the bushings and ball joint. The bushings come out by hand. The ball joint can be replaced without a press with a ball joint clamp loaner tool available at Advance or AutoZone. Just did on my XK8. You have to cut the lip of the ball joint to remove. Directions in workshop manual.
Old Oct 25, 2025 | 07:54 AM
Highhorse's Avatar
Do a search using JLM21380 ...you'll get URO Parts (on Amazon, if you have Prime you save shipping), Moss Motors, some dealerships. Check SNG Barrett... https://www.sngbarratt.com/English/U...SPENSION(14714) ...you'll have to type in Rockauto to search on them, but they have several options.
Verify any parts by cross referencing with other sites.
wombat
Apr 30, 2026 02:13 PM
07xjr
22
May 4, 2024 05:47 AM
TimCumming
May 13, 2022 02:43 PM
SD96XJ6L
Oct 6, 2015 07:54 AM
