Use too much gasoline?
Old Aug 26, 2019 | 05:47 PM
chris-jag's Avatar
Originally Posted by nilanium
- the coupling between the MAF and intake tube was slightly loose, causing the intake to pull away from the MAF bracket a bit under high engine load and let in some unmetered air.
For this, you can try removing the air filter housing, look at the support brackets that connect it to the body, bend them a little so that the air filter is a little closer to the maf.
This cured my problem with that problem as it kept recurring and was driving me a little nuts :-)
Kaleb McCann
Aug 11, 2019 11:02 AM
JimC64
US Mid Atlantic
Dec 23, 2014 09:01 PM
lockbustersinc
Dec 3, 2013 02:11 PM
Ipc838
Jun 7, 2012 12:56 PM
jbalbo
Nov 15, 2010 09:01 AM
