What lug nut fits the Penta rims?
Old Apr 24, 2013 | 02:27 PM
Brettl's Avatar
Default What lug nut fits the Penta rims?
Does Jaguar use different lug nuts for different rims? Can anyone post a picture of the correct nut so I am sure. I have lug nuts that fit my VDP rims and I am not sure if they will work on the Pentas I am purchasing.
Old Apr 24, 2013 | 04:01 PM
Fishfoolbear's Avatar
They should work on the Pentas, but depending if they are the long or short type they might look odd.
I had Pentas as summer wheels and Asteroids as winter wheels, and when I changed to Asteroids the lug nuts stuck out a lot (see pic), but they held as the nut holding part is at the same position (if you get what I mean).
Pentas look a little odd with short nuts and if you look around the correct nuts can be had from a scrappy relatively cheap.
I thought about buying some lug nuts others have used (Lexus or Toyota nuts seemed to fit) but the Germans are mad about using the correct part on your car, so I went with used Jag originals from the scrappy.
Regards
Lincol
DrTripp
Mar 22, 2020 09:33 AM
slojotaa
Oct 16, 2019 10:22 AM
lickahotskillet
Oct 18, 2015 09:51 AM
lickahotskillet
Sep 11, 2015 07:54 PM
ferraripete
Sep 10, 2015 01:24 AM
