What's the offset on these?
Old Aug 27, 2019 | 08:32 PM
KingJag93's Avatar
Default What's the offset on these?
1999 XJ8 wheels are toast, and going to replace with something similar. What is their offset?
Planning on replacing with the "Dynamic" wheels off the x350 generation. Ok fitment?
First picture is what I have found for a reasonable price to replace with.
Second picture is of the wheels on the car, and that I want to know the offset of.
Good to go?
Thanks!
Attached Thumbnails What's the offset on these?-20190821_115112_1566402700268.jpg   What's the offset on these?-screenshot_2019-08-27-21-16-40.png
Old Aug 27, 2019 | 08:46 PM
M. Stojanovic's Avatar
You can't use wheels from an X350 as their bolt spacing (PCD) is 5 x 108 mm and the centre bore is 63.4 mm and X308 uses PCD of 5 x 120.65 mm with centre bore of 73.8 mm. Otherwise, the offset of the X308 wheels is 33 mm.
Old Aug 27, 2019 | 09:16 PM
King Charles's Avatar
Just find some Asteroids or Pentas & swap away.
Old Aug 27, 2019 | 09:55 PM
ericjansen's Avatar
Originally Posted by M. Stojanovic
...... Otherwise, the offset of the X308 wheels is 33 mm.
Additional note:
On the Jaguar OEM 16" and 17", yes, ET33 indeed.
On some wider 18" OEM, the offset became less, to compensate for the wider rims (>8.5J).
Old Aug 27, 2019 | 10:20 PM
Yes, here's a table also showing the larger/wider wheels:
Old Aug 27, 2019 | 11:40 PM
KingJag93's Avatar
Great information folks!
Old Aug 10, 2024 | 04:06 PM
AnantaG.'s Avatar
One information that seems non-existent and would be an absolute savior is the measurements of the actual XJR 308 front spacing and backspacing. The car, not the wheels. Wouldn't that solve all the questions regarding what wheels, tires and offsets one could use for it? I am desperately trying to find that info as I don't have the car yet and am looking into wheels for when I buy it. Anyone can share those measurements maybe? I am trying to get hold of some owner to tell me that but so far unsuccessfully. Thanks.
Terrance39
Aug 22, 2021 01:50 PM
Leet8845
Mar 27, 2019 08:57 AM
XJ8Lou
Jan 9, 2017 07:50 PM
Zorasmiles
Nov 23, 2013 07:37 PM
