wheel alignment
Old May 3, 2008 | 01:16 PM
H20boy's Avatar
Default RE: wheel alignment
Old May 5, 2008 | 07:31 PM
jag_genius's Avatar
what do you have caster set at? i usually set it at 5.0 on the left and 5.5-5.6 on the right for road crown and when you had the bushings replaced.. did you have the car on the floor or on a drive on ramp.. and with the bolts loose shake the suspension..and then tighten? as the car settles down.. if it was tightened in the air.. the car is constiantly being slightly lifted as you are driving down the road..and also have you tried swapping tires left toright on the front? makes a big difference if one tire has a belt that is shifted..hope thishelps..
Old May 7, 2011 | 04:40 PM
pauljoane's Avatar
2001 vanden plau with left front camber at -0.67 and dealership wants to replace upper control arm for $1000. Do any of you have any advise. Paul
H20boy
Dec 24, 2024 03:23 PM
PMKimpton
Aug 3, 2019 08:22 PM
DustysSon
Sep 13, 2015 04:17 AM
lickahotskillet
Sep 11, 2015 07:54 PM
ferraripete
Sep 10, 2015 01:24 AM
