x
Old May 26, 2007 | 09:36 AM
Envy337's Avatar
Default RE: side lights and instrument panels... dont work all the time
Check the dim switch on the steering colum. Check your fuses again.
Old May 29, 2007 | 04:29 PM
Envy337's Avatar
Do you have power tilt on your steering column? If so, sometime it does chafe wires.
The steering colum is easy to remove, just screws. Take the bottom piece first (2 screws) and then the top (3 screws) and inspect the wiring closely.
