x
Old Jul 1, 2007 | 09:45 AM
jag_genius's Avatar
Default RE: 2 speedo lights out!
pretty easy to do.. but buy the bulbs from a jag dealer.. 8 dollars each..remove veneer making sure the tilt is all the way down..pull venner outward .. held in by clips. then get long screw driver remove 4 screws.. then remove plastic trim disconnect the trip and fog light switch ... then 4 morebolts that hold the instrument pack i think there 7 mm or 8mm bolts.then disconnect the pack.. pull pack out .. dont scratch lens..then with pliers becareful and turn each bulb housing left 1/4 turn then out.. replace all bulbs .. and ur done.
Old Jul 2, 2007 | 06:13 PM
jag_genius's Avatar
your welcome.. i guess you dont have to use jag bulbs but make sure you match the wattage... or you can have some issues..
