XJ8 1998
Old May 11, 2008 | 04:44 PM
JagtechOhio's Avatar
Default RE: XJ8 1998
You should update the water pump and tensioners. They are not the latest revisions.
Old May 11, 2008 | 06:08 PM
FactoryJaguarTech's Avatar
If the car is in good working order, you should be able to drive it. Before you head out on the road however, let it idle to operating temp then drive it 20 miles or so with the a/c on. If all is well, hit the road jack. Where in Florida are you buying it and when?
We have a meet in Port St Lucie May 17th. Swing by and we can give it a look for you.
On the plus side, even without newer tensioners, your engine should be steel sleeved.
Old May 12, 2008 | 05:05 AM
alot of that will depend on the money you wish to spend. If money is tight for you, you can do only the secondaries. If money is a little more accessible, I recommend doing both. Especially if you are planning on keeping/driving it for a while.
larrym
Dec 7, 2015 11:13 PM
Tally Ho
Oct 1, 2015 01:49 AM
donald ebanks
Sep 30, 2015 07:08 PM
Johnken
Sep 30, 2015 02:46 PM
moff1959
Sep 26, 2015 05:35 PM
