XJR cruise control problem
Old Oct 23, 2009 | 03:33 PM
hlgeorge's Avatar
First quick check: Is your CHMSL working? (3rd brake light) If it goes out some cars shut down the cruise system.
Old Oct 23, 2009 | 06:42 PM
Markus's Avatar
Check to see if all the brake lights are working. If the brake light switch (mounted on the steering column) is defunct, the cruise control won't work.
________
Old Oct 23, 2009 | 08:25 PM
test point's Avatar
Partially hidden in your original post is the fact, I believe, that the car was in 'restricted performance' mode. You are going to have to resolve that before anything else.
Old Nov 7, 2009 | 11:35 AM
FactoryJaguarTech's Avatar
Chances are the throttle body is bad. It will flag restricted performance but store no normal DTCs. Dealer can do a throttle body download and check to see if it flagged throttle failure.
Forcedair1
Sep 8, 2025 01:57 PM
jdzubas
Oct 4, 2015 09:14 AM
laserguy
Sep 3, 2015 02:02 PM
XFR_Gold
Sep 2, 2015 12:24 PM
