xjr rims on an xj6?
Old Feb 25, 2008 | 06:35 PM
jag_genius's Avatar
Default RE: xjr rims on an xj6?
i believe it is the same bolt pattern .. jag has used it for years.. it may be to wide for the xj6
Old Feb 26, 2008 | 04:15 PM
ken@britishparts.com's Avatar
No problem bolting the wheels up. You may find that the rears will rub the fender. You can have a body shop roll this portion to add a little clearence.
Just in case it comes up at a party: you can pretty much interchange all XJ6, XJ8, XJS, and XK8 wheels up to 2003. You will run into some caliper clearance issues. S-type and X-type will not fit on the bigger cars.
DrTripp
Mar 22, 2020 09:33 AM
slojotaa
Oct 16, 2019 10:22 AM
2010 Kyanite XFR
Feb 16, 2016 11:40 AM
