XJ40 ( XJ81 ) 1986 - 1994
blend doors
Old Mar 22, 2008 | 09:37 PM
gjagone's Avatar
Default blend doors
I have 89&86 xjs on the 89 the heater-evap door not working anybody know vac or elec opration which side for door i guess pass. have heat all the time also only def blower no vent or floor.
[IMG]local://upfiles/3474/797E1D3EFFD54F0B9D55043E57E7EA00.jpg[/IMG]
Old Mar 22, 2008 | 10:01 PM
Keith's Avatar
Default RE: blend doors
Possibly vacuum leaks in the system. Also, possibly AC Amplifier. See if you have vacuum at the hot water valve located on the firewall. No vacuum makes it stay open, letting hot water into the matrix. When vacuum is applied, it should close, keeping hot water out. The valve itself could be frozen open. You can still get the original valves, or plastic ones that work just as well, for a lot less money. Report back, maybe we can go from there if its something else. Keith.
Old Mar 22, 2008 | 10:14 PM
JagtechOhio's Avatar
Vacuum leak yes, amplifier no on an '89. There are two vacuum solenoids on each side of the climate control, operated by the climate control ECU. They fail regularly. I can't recall at the moment, but I think the defrost solenoid is on the LH side, it's behind the console side panel. Look for green plastic hoses, that is the defroster flap vacuum supply.
Old Mar 23, 2008 | 09:50 AM
jag_genius's Avatar
i just had a 89 dash out. i think the defrost solenoidis on the left side.
99xk8guy
Sep 29, 2025 10:51 PM
kevinl
Oct 31, 2019 06:15 PM
Gerard Radimaker
Sep 13, 2015 10:33 AM
RaceDiagnostics
Sep 13, 2015 02:22 AM
brgjag
General Tech Help
17
Sep 9, 2015 07:34 AM
