XJ40 ( XJ81 ) 1986 - 1994
Chassis lube points
Old Jan 21, 2009 | 08:56 AM
ArmyJag's Avatar
Default Chassis lube points
Well I'm going under the jag in a day or two to change the diff lube and I'm planning on taking the grease gun under there as well. So are the grease zerks in the common places or are there some that are the super secret squirrel type that I need to look out for. Don't want to miss things that need lube advice as always is appreciated.
Old Jan 21, 2009 | 04:31 PM
ArmyJag's Avatar
Default RE: Chassis lube points
Ok so I found a lot of grease zerks in places I wouldn't have guessed and decided I need a lift lol.
The quick question is where is the fill point on the differential?
Old Jan 21, 2009 | 06:59 PM
ArmyJag's Avatar
Never mind found the fill point on the Diff.
any super secret zerk locations would still be appreciated
Old Jan 21, 2009 | 07:20 PM
JagtechOhio's Avatar
one grease fitting on each of the inner and outer half shaft universal joints. Only ones on the car.
Old Jan 21, 2009 | 07:26 PM
ArmyJag's Avatar
nothing on the drive shaft? I noticed there was no uj at the rear but hadn't got forward yet.
Thanks by the way Jag Tech
MrWhite
19
Jun 14, 2022 07:49 PM
jagent
Jun 5, 2022 02:18 PM
magmedia
Aug 15, 2019 08:54 PM
Dave1109971
Dec 15, 2015 06:16 PM
MrWhite
Oct 1, 2015 01:43 AM
