XJ40 ( XJ81 ) 1986 - 1994
Crank damper/ pickup ring replacement, '94 XJ6 4.0
Old Nov 21, 2011 | 07:23 PM
edselsouth1's Avatar
Default Crank damper/ pickup ring replacement, '94 XJ6 4.0
I had posted this by mistake in the XJS forum, but will post it here as a follow up. 1994 XJ6, 4.0 engine. I'm a new Jag owner (haven't received the car yet), so I'm going by what the PO has told me. The pickup ring on the back side of the balancer has come loose, and now the car will not start (understandably).The damper is still firmly bolted to the crankshaft end. Does the crankshaft position sensor mount in the front cover? If so, would the loose pickup ring likely cause damage to the CPS, or is it recessed enough to prevent this? Are replacement rings available, as they bolt to the back of the crank damper? If a new (used) damper is needed, maybe someone on this forum has one available to sell. Thanks for your knowledge and time. David.
Attached Thumbnails Crank damper/ pickup ring replacement, '94 XJ6 4.0-1994-jaguar-xj6-003.jpg
Old Dec 5, 2011 | 10:31 PM
Default 1994 XJ6 balancer/etc.
Parts located locally. Vehicle repaired. Thanks... David.
fast40driver
Apr 19, 2024 07:24 AM
weisberg
May 14, 2022 03:18 AM
rusty37
Jun 7, 2016 04:43 PM
Fraser Mitchell
Oct 1, 2015 04:06 AM
cheaperts
Aug 30, 2015 06:48 PM
