XJ40 ( XJ81 ) 1986 - 1994
door booties
Old Nov 13, 2013 | 09:25 PM
manwich66's Avatar
Question door booties
does anyone know where to look for the part # (or know the #) for the bootie that covers the wires that go through the door jamb and into the door? I have two cars worth of cracked and torn wire booties.I know these will be a pain to change,but i have to go inside the doors at some point on these cars. any thoughts if they can be obtained for cheep?thanks all,Jim.
Old Nov 13, 2013 | 09:49 PM
Lawrence's Avatar
Here you go, front sleeves DBC1093, rear DBC1094
illustrated here
Harness Shields and Grommets - Parts For XJ6 & XJ12 from (V)667829 to (V)708757 | Jaguar Classic Parts UK
Old Nov 14, 2013 | 11:49 PM
manwich66's Avatar
thanks,i looked around and could not find a part #,very rare info.what do owners use as a part now?does something else fit? many cars were fitted with these types of autobody shop supply,are there alternatives?
Old Nov 15, 2013 | 03:10 AM
Lawrence's Avatar
Must be lots of cars that used this system in the 90's - maybe some still do - I'd try having a walk around a wrecking yard and take a look. They all clip on the sheetmetal the same way, I guess you've just got to match up the size.
My buddy has a 90's Caddy, if I see him at Tim's on Saturday I'll have a look at his.
Old Nov 17, 2013 | 11:12 AM
Lawrence's Avatar
I wasn't able to check the Caddy as he didn't show up but looked at a Camaro and a Chevy venture, both use same system but gaiters are oval and wouldn't work. A friend said to check out Lordco, apparently they might have a generic selection of these things - sorry I couldn't be of more help.
99xk8guy
Sep 29, 2025 10:51 PM
99xk8guy
May 28, 2024 09:36 PM
kevinl
Oct 31, 2019 06:15 PM
LnrB
Sep 29, 2015 12:54 PM
RaceDiagnostics
Sep 13, 2015 02:22 AM
