XJ40 ( XJ81 ) 1986 - 1994
DOT5 full synthetic yeah or nay?
Old Jan 27, 2023 | 11:21 PM
87octane91's Avatar
Default DOT5 full synthetic yeah or nay?
Stock factory 93. Thirty years old. 120k on the clock. Who knows what the the PO's did or didn't do to the brake system. Cheap shocks and rotors confirmed. Wasted lower control arm bushings and way screwy caster alignment attempt confirmed. Otherwise babied creampuff showing typical 30 yr old ailments.
Can I purge the brake system with a DOT5 transfusion or will any caliper/master/abs/pressure seals go AWOL on me? Who's done it? What happened?
Old Jan 28, 2023 | 02:10 AM
Lawrence's Avatar
We all have thirty year old + cars. Not a big a deal.
Mine has been a Northwest daily driver since it was a 17 year old car and has far more miles than yours. It has had it's quirks over the years but doesn't presently have whatever you assume are 30 year old ailments.
IMO, you should not use Dot5 synthetic and exactly why would you want to? Do the brakes not work right now? By all means replace the brake fluid if it needs it but stick to recommended fluid.
Larry
Timothy Geyer
Oct 11, 2022 12:24 PM
VancouverXJ6
Jan 5, 2020 10:32 AM
user 2029223
Feb 13, 2017 07:45 PM
GrahamPhotog
Jul 13, 2015 11:47 PM
JagV8
19
Aug 31, 2011 05:36 PM
