XJ40 ( XJ81 ) 1986 - 1994
fitted new battery,now out of park alarm on
Old Nov 19, 2012 | 05:31 AM
graham pritchard's Avatar
Default fitted new battery,now out of park alarm on
just replaced dead battery with new one and now out of park alarm is on, indicators and hazard warning lights dont work, interior lights for open doors dont work etc, car starts fine
any suggestions welcome
Old Nov 19, 2012 | 06:00 AM
Welcome to the forum Graham,
With a bit of digging I've found you have an XJ40.
(I've moved your post from General Tech Help section to XJ40 section so more members with the same model will see it.)
Can't be too serious when the only change has been a new battery. I expect the guys here can help you.
When you get a minute, please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST section and post some information about yourself and your vehicle for all members to see.
In return you'll get a proper welcome and some useful advice on posting to the forum.
Old Nov 19, 2012 | 04:00 PM
michael prichard's Avatar
Thumbs up new battery
20th instant,
RE:New Battery.
When either disconnecting old or fitting a new battery, irrespective of other advice, always refit postive (red) terminal first . Obviously then fit neg term'. This has alsways worked for me after I encountered the problems that you are now experiencing.
It may or may not work on your car, but I can say it is the safer way of re-installing your battery.
regards,
Michael P
Old Nov 20, 2012 | 09:49 AM
Default new battery fitted
this is driving me nuts, fault seems intermittent, car was on drive for several months in humidity (stupid me) all faults seem to be controlled via CPU unit hazard warning,indicators, seat belt warning,out of park warning, door open interior light etc, is it possible that cpu connections are damp or bad? running hard reset seems to work for limited time (minutes) then faults resume.
How long can I safely run hard reset?
can I try hair drier on cpu? where is cpu located?
any suggestions?
1992 XJ40, just changed battery from totally dead one to new one
Help please
Old Nov 22, 2012 | 05:44 AM
Smile fitted new battery - seems to be finally fixed
any suggestions?
Help please
disconnected battery totally, both P&N terminals, left overnight and did hard reset, cable to cable, no battery connection at all, for 15 mins (not sure that these two actions helped or not) reconnected battery as Michael Prichard recommended and everything is working again, thanks Michael for your advice
99xk8guy
May 28, 2024 09:36 PM
Rlover
Mar 30, 2016 10:04 PM
al_roethlisberger
Sep 11, 2015 10:04 PM
philwarner
Sep 3, 2015 10:14 PM
MC36
US Lower Atlantic
Sep 1, 2015 07:34 PM
