XJ40 ( XJ81 ) 1986 - 1994
Fuse for 92 XJ40
Old Jan 10, 2014 | 08:33 AM
Tanner87's Avatar
Default Fuse for 92 XJ40
Hey y'all - new on here.
The right headlight on my 92 XJ40 is not working, and a replacement bulb doesn't work.
I have been doing some reading on the site, and it looks like the best bet is the fuse located in the center consol, not the fuse to the left of the foot pedals.
Can anyone confirm this, or has anyone had similar issues?
I'm guessing that just buying a new fuse and replacing it will (or might) solve the problem.
Appreciate it folks!
Old Jan 10, 2014 | 08:44 AM
mrtalkradio's Avatar
Welcome to the forum, stop by an introduce yourself in the new member area. After a few posts you'll be able to use the search function within this section which can help dial you in to your issue.
I suggest going and buying a Haynes Repair manual when you get a chance. Did you check to see if voltage is going to the bulb socket?
Old Jan 10, 2014 | 02:41 PM
It might be a center fuse box although I doubt it.
However you can download the above Haynes from the XJ40 section here.
XJ40 downloads.
aode06
Jul 28, 2023 02:26 PM
hoodun
Nov 20, 2022 02:35 PM
goingjag
Sep 30, 2015 09:27 PM
ziondio
Sep 29, 2015 01:58 PM
