XJ40 ( XJ81 ) 1986 - 1994
Headlight lens removal 1993 Jaguar Xj6
Old Feb 6, 2014 | 02:09 PM
Crownewourth's Avatar
Default Headlight lens removal 1993 Jaguar Xj6
Hey guys..I need to remove the headlight lens from my Xj6 (1993)...I am not really seeing where it comes apart..what am I missing? Thanks
Old Feb 6, 2014 | 05:53 PM
My UK spec XJ40 had the twin headlights but I expect you have the single rectangular pattern?
If so, they are held in place by four 13mm nuts at the rear.
Also remove the trim piece at the top of the lights (two screws) and the entire front grill. The grill is held in place by four 8mm bolts, but you'll need to remove the centre panels of the grill (2 screws each side) in order to get to them.
With the grill and the lights removed, unplug and remove the Bulb module (one 8mm bolt) and you should be left with a gaping hole:
kurtomatic
Feb 12, 2024 06:58 AM
97xj6lucy
Sep 3, 2015 07:44 AM
kesslari
Aug 31, 2015 04:53 AM
1100me
Aug 28, 2015 09:48 PM
SingBlueSilver
Aug 27, 2015 02:20 PM
