XJ40 ( XJ81 ) 1986 - 1994
That Jammed Shifter...
Old Jun 7, 2007 | 09:10 AM
XJ40ish's Avatar
Default That Jammed Shifter...
Hi, I'm wondering if anyone has encountered this problem? My 1993 XJ Sovereign's shifter will occasionally jam in park. The quick fix, is to simply yank on the shifter which seems to free it, but given the amount of force required, I'm sure this is not desireable. Is this a known concern, or is it something I need to have looked at?
Thanks for any feed back.
Roy
Old Jun 7, 2007 | 11:14 AM
bigdreams05's Avatar
Default RE: That Jammed Shifter...
The fix I'm unsure of, but to prevent this from happening again do this:
1) When you are in drive, about to park, put the car in neutral and for just a sec let go of the brake.
2) Now with the brake pressed in, pull the Emergency Brake up and now put the car in park.
You'll now see how much easier it is to put the car in drive again. Good luck, and come back and let us know what you think!
Old Jun 9, 2007 | 08:31 PM
XJ40ish's Avatar
Actually... I'm told to simply step on the brake again and this shouldrelease theshifter.Failing that, you simply remove the star shaped screw thingy next to the shifter and depress the lever under it with a screwdriver. Geez I am such a yutz.
Old Jun 15, 2007 | 09:49 AM
XJ40ish's Avatar
Hey! Guess what, there's a TSB on this exact problem. Wonder if my 93's still under warranty for this recall??
Old Jun 15, 2007 | 10:51 AM
lol. Good luck!
Old Jun 15, 2007 | 10:56 AM
XJ40ish's Avatar
What??? You think they might not warranty it? I find that highly unlikely...after all it is a Jag!
n8ertot
Oct 11, 2015 02:28 PM
WinterJag
16
Oct 9, 2015 07:49 PM
Spazzzzzzzzzy
Oct 4, 2015 05:37 PM
waynepaulj
Oct 2, 2015 04:05 PM
3jagfamily
Oct 1, 2015 01:49 AM
