XJ40 ( XJ81 ) 1986 - 1994
Location of Lightin Logic Unit (LLU)
Old Oct 26, 2011 | 08:05 AM
mdmike52's Avatar
Default Where is Lighting Logic Unit (LLU) on '94 XJ6?
Can anyone tell me the location of the Lightin Logic Unit on a 94 XJ6 ?
My XJ6 just developed a bizzare headlamp problem. The left hand low beam will not go out until the ignition is turned off, the left hand HIGH beam will not go out ever, even with ignition off. The high beam indicator on the dash is always on, the hi/lo beam switch has no affect, and the right hand high beam will never come on. Also the fog lights will not come on. Sounds to me like LLU went Nuts.
Crazy Huh. Problem started when someone flashed their lights at me , my Hi beam indicator was off so I hit the high beam switch to test them. The high beam indicator came on and would not go back out, when I arrived at my destination the left haedlamp lo beam would not go out with the headlight switch but went off when ignition was turned off, left Hi beam stayed on, I had to unplug the bulb connector.
Where is the LLU ??
Any Help will be greatly appreciated.
Mike
Old Dec 27, 2012 | 01:10 PM
Astroman's Avatar
Hi. Did you ever solve this problem. I have the same on my car?
bamforp
Aug 14, 2024 05:36 PM
Aus V8S
Nov 13, 2015 11:01 AM
08Z06
Oct 24, 2015 05:46 PM
Guy-Pierre Boucher
Sep 16, 2015 05:55 PM
al_roethlisberger
Sep 7, 2015 10:53 PM
