XJ40 ( XJ81 ) 1986 - 1994
Matching cylinderhead
Old Today | 12:41 PM
bfa1's Avatar
Default Matching cylinderhead
I am a rookie with this forum, so thanks for answering!!
As a proud owner of a 1989 xj40 3,6 Sovereign with a damaged cylinder head gasket, I am actually overhauling an other Engine with the aim of exchanging the two.
So, I have a 9DPAMA Block (early 3,6 ??) fitted with an eac7077 cylinder head (late 4,0 ??), furthermore I have got an eac4002 cylinderhead, which I have already restored a few years ago.
My question is whether I can fit the eac4002 head in the 9DPAMA Block without getting an trouble, maybe you guys have more insights.
Greetings, Boris from Bavaria
Old Today | 07:31 PM
Lawrence's Avatar
You will need a valve cover to match the 4.0 as there are 13 bolts securing it ...there may be other differences but can't think of any ...check that the cylinder bore of both engines are the same too.
On the other hand, why not check the head for level/get it machined and refit it?
Old Today | 07:55 PM
jerry_hoback's Avatar
The head gaskets are a known weak spot. just get the gasket kit and put it back together---
Old Today | 08:21 PM
Lawrence's Avatar
That's what I did last December, head was flat as a pancake and didn't mess with valves either. 300,000kms just around the corner, running sweet as a bird.
JensenHealey
XJ40 ( XJ81 )
Nov 18, 2024 04:12 PM
Clouder
Oct 28, 2024 08:14 AM
JacobyJaguars
E type ( XK-E )
Nov 21, 2021 11:24 PM
AnttiM
Sep 2, 2019 06:49 AM
JRR705
General Tech Help
Mar 12, 2016 03:54 PM
