XJ40 ( XJ81 ) 1986 - 1994
Are my lower shock mount bushings shot?
Old Apr 11, 2017 | 09:47 AM
NTL1991's Avatar
Default Are my lower shock mount bushings shot?
I was swapping over my summer tires yesterday and snapped a couple pics of the lower shock mounts to give you guys something to look at.
Should I be seeing light through them??
Old Apr 11, 2017 | 11:13 AM
Lawrence's Avatar
Nope!
I replaced the lower bushes when I changed the shocks and drop-links a few years ago - got aftermarket bushes which fit quite well but the central sleeve hole was a bit on the sloppy side for the lower shock bolt ...so maybe something to keep in mind ...
OTOH the outer sleeve was very tight, even on the old ones I removed so if you're seeing light, something is definitely amiss!
Larry
