XJ40 ( XJ81 ) 1986 - 1994
no heat and stumped
Old Sep 16, 2011 | 08:59 AM
skertz's Avatar
Default no heat and stumped
No heat in 94 XJ6. Thermo is ok as coolant reaches correct temperature. Coolant levels correct. Checked the heater control valve on back cylinder and it is not stuck closed. It operates correctly with a/c closing it too. I operated by hand and with vacuum. Next the hose going to firewall from HCV is hot. However, hose coming out of firewall back to water pump is cold. Per Haynes manual ran a hose of water into line in firewall to check if heater core was impeded or blocked. It is not. Ran hose of water through lines at HCV and water flows nicely through. So if coolant going to heater core inside car is hot, and blowers work, then why is return line cold? Both lines should always be hot if HCV is open which it is.
Old Sep 16, 2011 | 12:48 PM
What you did makes sense to me.
Have you tried running it up unpressurised (cap off) to chase an air-lock?
Your water pump is working??
Old Sep 16, 2011 | 02:36 PM
uropnm6's Avatar
+1 possibly air or a blockage in the return line?
Old Sep 17, 2011 | 08:14 AM
skertz's Avatar
Thanks for suggestions. Was thinking water pump or air void too. Because I took one line off at firewall and flushed with garden hose and appears to be no blockage in heater core or any lines as water flows. Will try running unpressurized. Does seem that maybe water pump is not circulating well enough as not much pressure felt on top or bottom radiator hoses.
Old Sep 18, 2011 | 05:07 AM
Cadillac's Avatar
Don't forget to keep us updated, hopefully it will work for you
Old Sep 18, 2011 | 04:31 PM
Fraser Mitchell's Avatar
Isn't there a small electric assister pump on the heater hot supply ? If this fails it can act as an obstruction, rather than an assistance
aode06
Jul 28, 2023 02:26 PM
NathanDD6
Oct 6, 2015 11:20 AM
Delta66
Oct 4, 2015 05:40 PM
Newark Nj Gang
Oct 2, 2015 02:39 PM
Lawrence
XJ40 ( XJ81 )
Oct 1, 2015 08:36 AM
