XJ40 ( XJ81 ) 1986 - 1994
Possible oil leak, general tidbits...
Old 03-01-2022, 02:53 AM
mickvic's Avatar
Default Possible oil leak, general tidbits...
Just a couple of things to watch out for...oil filler cap....rubber o-ring on it. Replace, will cure some leaks, and car will idle better.
Replaced your rocker cover gaskets couple years ago? Seeing leaks at the top of the screws ? Try it they will be loose. 25nm torque I believe.
Brake pedal rubber worn? New ones cheap...and easy to put on!
No dash lights? I put up with it for years fiddling around then replaced the switch with good second hand. Bingo...dash lights!! Checked the back of the instrument panel had a couple of globes out as well.
Mick from melbourne AU
garethashenden (03-04-2022)
Doug
11-25-2020 08:27 PM
Doug
11-22-2020 09:02 AM
hacker-pschorr
04-07-2010 10:25 AM
Quick Reply: Possible oil leak, general tidbits...
