XJ40 ( XJ81 ) 1986 - 1994
Relay Module?
Old Oct 11, 2007 | 11:35 PM
estunum's Avatar
Default Relay Module?
My front passenger side low-beam headlight is out. -----> ([sm=smiley11.gif])([sm=smiley1.gif]) ([sm=smiley1.gif])([sm=smiley1.gif]) All four bulbs are good, so its not that. All the fuses are good also. If I switch high-beam, all four headlights work great. I ran out of ideas. As a quick fix, I even tried disconnecting the high-beam lights, so that when I switch to high-beams, only my low-beams remain lit. I quickly learned that when I switch to high-beams the low-beam lights get brigher, so I wasn't able to drive like that without unhappy oncoming drivers. Is there something I can do to see if its the relay module? I really don't feel like switching the two out, but if I must, I will.
Old Oct 12, 2007 | 07:02 PM
93xj6's Avatar
Default RE: Relay Module?
The relay models, at least on the 93s were pretty easy to check. just go to teh relay try pushing it in tighter and see if the light works than.
hoodun
Nov 20, 2022 02:35 PM
NS2000XKR
Jan 1, 2017 10:41 AM
leep123
Sep 30, 2015 03:41 PM
zdrapec
Sep 25, 2015 05:49 AM
