XJ40 ( XJ81 ) 1986 - 1994
Remove brake Accumulator
Old Jul 19, 2021 | 08:08 AM
mickvic's Avatar
Default Remove brake Accumulator
Ok got a new one to go on...a mercedes bosch one I bought on ebay...now getting the old one off what is the best method....I read its a no no to put a big alan key in the recess in the top, but that seems to be the only way to turn it. Apart from that brace the pump assembly....and turn ignition to on and pound the brake pedal until it goes hard....
Old Jul 24, 2021 | 01:06 PM
catmanboo's Avatar
Just recently did mine. I wedged it tightly in place, then used a hex bit & ratchet wrench. One hellish grunt later & it was off. Alternate is to use a strap wrench. Screwed on new one, a GM equivalent replacement from the bay & tightened with strap wrench due to no hex on top. Problem instantly solved! (delayed braking due to failed accumulator.) Now I can drive it anywhere, anytime!
Old Sep 8, 2021 | 05:18 AM
mickvic's Avatar
chickened out got the shop to do it. Mercedes bosch one...smaller but works a treat car stops now.
Robbo D
Jun 24, 2020 08:02 PM
SamtheSham
Feb 15, 2019 10:01 AM
JayJagJay
May 30, 2018 05:52 PM
mark1210
Nov 1, 2017 11:41 PM
JaguarXJ6
XJ40 ( XJ81 )
Aug 26, 2012 07:58 AM
