XJ40 ( XJ81 ) 1986 - 1994
Xj 40 6.0 V12
Old Oct 25, 2014 | 09:35 AM
Bleujag's Avatar
Default Xj 40 6.0 V12
Would like to have some advise.
Went to look for a Xj40 (1993) V12 6.0.
Car looked fine except for a oil leak in the front, most likely the stearing.
Is this a common problem for this type and is it a expensive fix?
Also there was moist in the boot originating on the leftside tankfiller. Could it be a clogged up waterdrain under the filler cap?
Thanks,
Old Oct 25, 2014 | 11:13 PM
Rok_Dr's Avatar
Hi
Others more knowledgeable than me will be able to advise on the power steering leak. Being an xj12 owner for just a couple of months I'm still on the steep part of the learning curve.
As to the boot leak that sounds about right. An xj40 I recently looked at just before I bought my xj12 had the same problem. It had been parked in the rain and the rubber surround under the filler cap was full of water.
Steve
workworkwork
Oct 1, 2015 01:44 AM
MattB731
Sep 30, 2015 10:37 AM
marklcap
Sep 29, 2015 12:41 PM
redgear
Sep 26, 2015 07:21 AM
