1984 XJ6 S3 Battery Light On
Old Aug 19, 2018 | 04:12 PM
twocross's Avatar
Default 1984 XJ6 S3 Battery Light On
Hi all,
My XJ6 S3 had the battery light come on with voltmeter needle at about 11v while running. About 300 miles ago I replaced the alternator, and in the spring I put in a new battery. I checked battery for bolts and it’s at 14 volts (tight connections on + and -). Alternator connections are tight also. Cleaned up grounds also. I’m at a loss for what to check next.
Thanks in advance,
Alan
Old Aug 19, 2018 | 09:38 PM
Doug's Avatar
A little weird.
At 14v the alternator is obviously fundamentally working.
Since you've checked the wires and connections I have to think there's a problem with the alternator
Does the light stay on even with the ignition off?
Will the light turn off if you rev the engine up?
Old Aug 19, 2018 | 09:39 PM
Trektech's Avatar
Default Low volts
Did the new alternator charge properly when first installed, or did it never charge? My first go-to check is clamp one end of a jumper cable to a alternator mounting bolt, and the other end to the battery negative post to check for proper ground. I have installed New alternators that we're bad right out or the box.
Old Aug 20, 2018 | 11:22 AM
twocross's Avatar
It has been running great. No issues at all. One morning I drove it and the light came on and the voltmeter pointed to just the edge of the red marking at around 11volts. If I get the rpms to 2000 and above the light goes off momentarily. Every once in a while the bolts on the gauge would rise to the center of the voltmeter for a few minutes then drop back down. I drove it for about two hours last night around town to see what would happen. Well it drove fine, but I noticed the windows were slow to go up or down. I checked the battery when I got back and it read 15.4 volts.
Old Aug 20, 2018 | 01:11 PM
Jose's Avatar
what alternator did you buy? I replaced the original Lucas alternator in my 1984 with a more amps is better GM alternator, and I was never happy with the GM alternator. Fortunately I kept the old Lucas and problem solved.
most likely it is the alternator.
Old Aug 21, 2018 | 10:23 AM
twocross's Avatar
I saved the Lucas alternator as well, however the voltage regulator in it was faulty. I’m going to try to ground it better. I’ll try that jumper to the battery ground and see what happens.
Old Aug 21, 2018 | 02:01 PM
Jose's Avatar
Mike Martinez in California rebuilds all sorts of classic car Lucas generators and alternators. Star Auto Electric is his business.
Based in my experience, I prefer the Lucas, it seems to be better calibrated to the XJ-6 gauge.
Old Aug 22, 2018 | 11:57 AM
JagCad's Avatar
I sure dunno know. English volts and amps are the same as American !!!
But, a well rebuilt Lucas will trump a poor Delco.
OTH, many Jaguars are doing well with either.
My lump excels with its 140 Amp Delco. A really large unit up top, right front. Serpentine belt driven a sure positive.
A while back. I created a patch cord. enabled my HF VOM to connect at the cigar outlet. Real volts I real time at various loads and RPM's. One of my better ideas. Convicted a battery and acquitted an alternator !!
VOMs are great !! All three of my cordless driver/drills were flat when needed !!
A session on their chargers revived two.
The third, a slick angle drill, zip!! Oh me, a charge session got only 7+ volts. 18 or near about needed. Back to the charger. Hope for 18 faint ! it may leave
Carl… …. ...
Old Aug 22, 2018 | 08:19 PM
Doug's Avatar
You're right, Carl.
There's nothing inherently sub-par about Lucas alternators. They're as good as any other. The problem, at least on Series III cars, is that Jaguar specified (or settled for?) a unit that was just barely up to the task in terms of output.
Once any alternator has been rebuilt...Bosch, Lucas, Delco, Motorola, Denso, whatever...future performance and longevity probably has more to do with the quality of the rebuild than the original make/brand.
Old Aug 22, 2018 | 08:23 PM
Doug's Avatar
Calibrated to the gauge?
The voltmeter does have an adjustment to correct for a too high or too low reading.....but it has no way of knowing if the volts are being generated by a Lucas alternator or Delco or whatever. It just reads voltage. The alternator and voltmeter are not calibrated to each other.
Old Aug 23, 2018 | 09:52 AM
JagCad's Avatar
Yup!!
My Jaguar's guage reads the same with the Delco as it did with the Lucas. By nature the gauges are a bit slow on the uptake. And, for me more of an indicator than true guage. Hence, my patch cord device to verify from time to time.
And, when things electric go odd, go the ground route. Not forgetting the down and under one at the engine transmission joint. Very important.
decades ago, I was messing with my Webber equipped turbo Corvair. Lots of effort at the very tunable Webber to correct a flat spot in acceleration., Not getting anywhere. then my bare elbow touched the nearby battery ground cable. HOT!!!! Not good, much resistance, poor connection! Indeed, it had one of those "Mickey Mouse"
clap on the at the battery - post. Should 've dumped that a long time ago. My shop wall yielded a much better cable. Installed, cleaned at both ends. !!!! Flat spot gone.. revved like a champ...
Carl
Old Aug 26, 2018 | 05:06 PM
metalbasher's Avatar
Had this same problem with the Silver Six (earlier '85 SIII). Replaced the big spade terminals at the alternator with ring terminals and the problem disappeared.
XJkid
Oct 17, 2011 08:56 PM
rrthomas
Jul 26, 2010 07:14 AM
IceCold971
Dec 24, 2009 05:05 PM
raj139
Feb 3, 2009 02:55 PM
ciscosurfdog
Oct 28, 2008 06:34 AM
