1986 xj6 III 4.2 electronic ignition
Old Oct 12, 2013 | 10:00 PM
Hoppo's Avatar
Default 1986 xj6 III 4.2 electronic ignition
I have a 1986 xj6 III 4.2 automatic & changed the Lucas distributor & coil for a Pertronix flame thrower. I have disconnected the amp & wired the distributer direct to the coil & did the timing,blocked off vacuum set timing at 20deg BTDC @1700 rpm now the motor has more power but it starts breaking down at 4500rpm.Can anyone help please.
Old Oct 13, 2013 | 02:58 AM
Welcome to the forum Hoppo,
I've moved your question from General Tech Help forum to XJ6 Series I, II & III forum. Members here with the same model should be able to help with the Lucas ignition issue.
When you get a minute, please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST forum and post some info about yourself and your vehicle for all members to see. In return you'll get a proper welcome and some useful advice about posting to the forum.
Old Oct 13, 2013 | 05:13 AM
Hoppo's Avatar
All sorted,checked ht leads making sure good fit,checked wiring & something worked as it has a lot more power than it has ever had.Like a completely different car.
Old Oct 13, 2013 | 06:03 AM
Final score: Australia 1 - Lucas 0
Good to hear you've got it fixed.
JarodL
Mar 7, 2024 01:39 AM
rusty37
Apr 5, 2020 07:40 PM
Charlene n John
Sep 14, 2015 12:01 AM
carcycle
Sep 7, 2015 04:14 AM
