1990 xj12- is this the right page?
Old Jun 6, 2011 | 12:16 PM
velder's Avatar
I know it is a wee bit of reverse engineering, but it would look wildly cool to have 2 rows of 6 carb throttle bodies on a v12 engine beneath the bonnet of a replica of a '30's something tank style race car. Does the gm tranny in this thing rely on any electronic signals? or could I scrap all the electronics in favor of a simple push button type of solenoid starter with very minimalistic wiring under the hood? Maybe yank a front axle out of a junker 30's - 40's whatever and use the existing jag rear end, cobble together some frame rails and have some modern-nostalgic fun.
Old Jun 6, 2011 | 06:11 PM
velder's Avatar
are these three speed GM transmissions at all controlled by wiring? I know some transmissions are ecm controlled but I figure that this is old enough to not be.
Old Jun 7, 2011 | 01:20 PM
justV12's Avatar
Transmission uses a cable shift which seizes with rust when left for long periods
and a semi electronic transducer to run the speedometer.
Nothing there that can't be overcome.
May I suggest you google "XJ-13" and consider building a replica of one of the sexiest Jags never made?
Old Jun 7, 2011 | 07:48 PM
velder's Avatar
How long back does one have to go to get a carb intake for one of these engines? Is it like really old and a lot of money? or like yesterdays junk not worth picking up?
Old Jun 7, 2011 | 08:08 PM
Doug's Avatar
The last of the E-type V12s were still on carburettors circa 1974/75. The V12 sedans got fuel injection about the same time...so for the 25 years the Jag used the V12 only the first 4 had carbs.
If you look long enough you could probably find what you need.
sadepol01
16
Nov 22, 2024 05:05 PM
SCMike
Nov 25, 2015 07:55 AM
leep123
Sep 30, 2015 03:41 PM
XJRick
Sep 28, 2015 02:12 AM
