6RA Relay and Starter Relay
Does anyone know the location of a 6RA relay? Supposedly there are two of them running off the ignition switch in order to prevent power surges to that switch, and I believe this is what is keeping fuses 6-9 and my fuel pumps from getting any power.
The other relay is the starter relay. I believe it is the one on the firewall in the middle-top. It has around 7 points in which to connect wires, but mine only has 5 wires hooked up. I do have 2 additional wires nearby, but a PO taped them to the wiring harness and had them plugged into nothing. The two open points on that relay are the two closest to the passenger side. The unplugged wires nearby are: 1 black, 1 white/red. Any help would be great. Any other ideas on why my fuse box and fuel pumps lost power would be greatly appreciated!
