82 xj6 intrument lights
Old Dec 10, 2012 | 05:15 PM
82jaguarxj6's Avatar
Default 82 xj6 intrument lights
so my jags dash lights arent working, the blinkers, warning lightds and everything else work though. there is also a couple wires hanging under the dash that have been unplugged that i dont know what they go too
Old Dec 10, 2012 | 08:23 PM
Doug's Avatar
What are the wire colors? They might go to the dimmer rheostat which on an '82 was located in front of the driver's right knee on the under-dash trim panel...as I recall
Old Dec 10, 2012 | 08:52 PM
black
purple w/ black stripe
black
red w/ blue stripe
red with white stripe
also only the red wires have female connectors on the ends
Old Dec 10, 2012 | 11:47 PM
also what does the dimmer rheostat look like?
Old Dec 10, 2012 | 11:54 PM
Doug's Avatar
Originally Posted by 82jaguarxj6
black
black
I'll try to figure these out when I have time
red w/ blue stripe
These are for the panel lights. Red/blue is voltage into the rheostat; red/white is outout to all the lamps.
Join 'em together and see if the lights come to life. In so doing you have bypassed the rheostat....which is probbaly juat as well because the rheostat often makes the too-dim panel lights even more dim
Old Dec 10, 2012 | 11:59 PM
Doug's Avatar
See pic #4 in this posting
https://www.jaguarforums.com/forum/x...c-parts-86073/
Your rheostat will be the same or similar
Old Dec 11, 2012 | 12:53 PM
sweet my dash lights work now! thanks a lot Doug! also a full tune up solved my ticking noise almost entierly.
Jpav27
Jul 31, 2022 06:43 AM
rusty37
Apr 5, 2020 07:40 PM
redrover41
23
Sep 25, 2015 01:33 PM
carcycle
Sep 7, 2015 04:14 AM
Chet Ramnarain (bozzner)
Sep 3, 2015 12:21 PM
