84 XJ6 Compression Check
Old Sep 13, 2011 | 05:19 PM
Benhamtroll's Avatar
Default 84 XJ6 Compression Check
I finally checked the compression in the cylinders today. I knew there were serious problems when four of the six plugs were wet. So, I plugged in the gauge and this is what I got (numbered back to front):
1: 130psi 2:160psi 3:70psi 4:90psi 5:150psi 6:105psi
Add into this the glorious fountain of coolant that was erupting out of the open cylinders, and I would say something needs to be done. I'm hoping it's just a head gasket at this point. The fact that the oil is not milky makes me hope that it blew pretty close to the end of the last time I drove it, and didn't get much chance to mix.
Any interpretations/advice?
Thanks!
Old Sep 13, 2011 | 07:43 PM
Doug's Avatar
Time to pull the cylinder head for a look-see :-). Head gasket failures are fairly common on the 4.2s.
Old Sep 13, 2011 | 10:13 PM
Yeah, that's the next task. I've neve done a DOHC before, so I'm trying to find a buddy who can help.
Old Sep 13, 2011 | 11:46 PM
Doug's Avatar
You'll need a couple of small bottle jacks for the job...to force the intake manifold off the cylinder head and to lift the cylinder head off the block.
bamforp
Aug 14, 2024 05:36 PM
rusty37
Apr 5, 2020 07:40 PM
carcycle
Sep 7, 2015 04:14 AM
Chet Ramnarain (bozzner)
Sep 3, 2015 12:21 PM
