85 Vanden Plas Airconditioner Wiring
I have what appears to be a broken connector on my AC compressor. The wiring harness connecting to the compressor includes a wire with a peculiar "half sphere" connector that is suppose to connect to the back of the compressor. However, there seems to be no way to attach this funny connector to the mating connector on the compressor -- they match physically, but there seems to be a part missing that allows them to make contact. This appears to be the signal that activates the compressor clutch, because I no longer have working AC. Is anyone familiar with this connector and how it can be "fixed" or replaced??
The superheat switch in the back of the compressor has a single small pin which makes contact with its female counterpart located inside the half-sphere connector
The half-sphere part itself is protective boot which fits over a lip/ridge incorporated in the superheat switch.
If the pin is broken or missing, or the female counter part is broken or missing, or the lip/ridge is broken or missing....the connector won't stay in place. It's all a rather tenuous friction fit
Doug, my compressor clutch no longer seems to be engaging. Is this function required to make the AC work? I believe the pin on the compressor is missing -- is this "fixable" without disassembling the AC system?
The superheat switch is part of the protection circuit. In essence the switch (and the three prong thermal fuse) will defeat the circuit to disengage an operational compressor. If the wire is left unhooked the compressor clutch can still engage....it's just that the protection circuit will be inoperative.
The system would need to be discharged to replace the switch....but 'disassembly' of the system is not needed
All is well -- the connector to the front of the compressor had become lose when I was working in there, and AC returned to working order when I re-seated that connection. Thanks so much for your insight.
