87xj6
Old Oct 6, 2020 | 07:50 PM
robroy's Avatar
Default 87xj6
Does anyone have advice on how to troubleshoot a tachometer? And especially how to determine if it's the tach or the wiring??
Thanks for any help.
Bob
Old Oct 7, 2020 | 12:23 PM
JagCad's Avatar
Precisely, no!
However, consider that the tach responds to pulses from the - post of the ignition coil. Very rapid as the circuit aka dwell is opened and closed....
Recreate in some fashion? Signal generator? Not any in my shop..
Work around. A long jump wire. One end to the - post on the coil. the other on the - post on the tach. check jaguar schematic S57 for the color... Run the engine. If the tach responds, it is the wire!
make sure the tach has + voltage, as well. Jump it in if not present..
Check S57 for + volts source..
Good luck with the electrickery...
Carl
mowog4
Sep 8, 2020 03:08 AM
Yash swamy
Apr 7, 2020 09:22 AM
eurocare
May 1, 2017 06:25 PM
PhilipM
XK120 XK140 XK150
Aug 14, 2015 06:40 AM
edsterp
Mar 12, 2010 08:05 AM
