A6 High Pressure Switch
Old May 9, 2016 | 04:04 PM
Dale Konkol's Avatar
Default A6 High Pressure Switch
My new compressor has a high pressure switch as opposed the superheat switch the old A6 compressor had.
Question. The old superheat switch had a single male prong sticking out for the female electrical connector to attach to.
The new high pressure switch does not have a male electrical connector. I'm not sure what sort of electrical connector is required.
Anybody have experience in this?
I've attached a pic of the back of the compressor showing the high pressure switch.
Old May 9, 2016 | 04:19 PM
Doug's Avatar
I don't see a pressure switch. I do see a 'pop-off' valve....but that's not the same thing. That's not an electrical device. It's a mechanical valve that trips at 400 psi or some such number
The pressure switch would go into one of those holes that is capped off with a plug and a snap ring
cheers
Old May 9, 2016 | 04:20 PM
Doug's Avatar
I wonder if that compressor is designed to take either a pressure switch or the superheat switch. If so, it probably matters which hole you insert the switch into.
Is there an info sheet with the compressor?
Old May 9, 2016 | 04:27 PM
There is an info sheet. But I don't remember it saying anything about the switch itself. Only that the compressor is of the type that has the high pressure switch.
Crap. I spent all day replacing that damn compressor. I hope I don't have to pull it again to get the switch installed. I guess I assumed that "pop off valve" was the switch.
Old May 10, 2016 | 08:21 AM
I found via 4 Seasons web site the correct switch to use.
But, it is a two terminal switch. My Jag wiring only has the one wire. Is this the correct switch? How do I connect? Also, does anybody know which port the switch would be installed in?
Thanks for any input.
