Almost done with my project a little more help please!
Old Nov 25, 2011 | 08:23 PM
perfectphoto's Avatar
Default Almost done with my project a little more help please!
Hi Everyone, I have the car running pretty good now. Here are some of the issues that i still have.
Any cheap fix for the fan clutch?
I was messing with the center consol and the window lockout button hit metal and sparked and now I don't have power windows and the gauges don't work any more.
I have no dash lights.
I can't get the idel to slow down without plugging the hole at the rear of the drivers side intake air cleaner that runs to the metering valve. I adjust the screw on the valve and the idel doesn't change.
The climate controls do nothing, they worked before I had the short at the center
Any help that you can give would be great, thanks so much in advance.
Tom
Old Nov 26, 2011 | 06:59 AM
uropnm6's Avatar
I think you should check the fuses! they should have blown before doing any major damage, as for the idle, it sounds you have a vacumn leak check for a hissing or whistling or look at all the hoses to make sure that they are not dry rotted. Good luck
Old Nov 27, 2011 | 04:46 PM
Fraser Mitchell's Avatar
Also there is NO cheap fix for the fan clutch, it has to be replaced if it is seizing up or making screching noises - I had one go on my '80 XJ6 some time around 1990. Clearly you can buy a used one but it could be defective and/or have come off a high miler have a short life.
04Xjrsteve
May 7, 2019 04:06 PM
pino
Sep 26, 2015 08:05 PM
BlacXJRcat
Sep 25, 2015 06:43 PM
